Just finished setting up my new speakers and dual LCD desktop mount. The mount was £60 but frees up a lot more space aswell as looking totally awesome![]()
Simmy - what make is the mount? Been looking for one for ages.
I'm not Simmy but I can tell you it's an Allcam MDM05 or MDM06. The 05 is a dual monitor stand, the 06 is a triple monitor stand. I have the MDM06 but use it with two screens - means I have a spare centre bracket if I ever get a third screen. I can also tell you the desk lamp is from Ikea because I have that too:
I stripped the fluorescent tube out of the lamp and replaced it with four MR16 12V LED clusters hence it looking subtly different.
It's late and I need to tidy up! At least the other side of the room is a tad less messy.
snip
What do you mean by different size, smaller? It's not actually meant for 24" screens, it's intended for much smaller. Those are Dell G2410s I'm using it with and I reckon that if I did want to add a third one I'd need to buy some extensions for the side arms, otherwise they wouldn't all fit together.Look good actually, any idea if you can use different size monitors?
, and very simalir bed framelol ikea boy - I have the same 2 seater and the same desk, and very simalir bed frame
i like the room setup
Taking the ****. No one needs that many screens, for the love of god you'll get rsi of the neck!!
Aaaanyway, what are the certificates on the wall for?![]()
Because i could![]()
p.s. sorry about poor quality, i was too lazy to get my SLR.
