1920x1080
That backlight bleed is totally normal and is just due to the nature of the IPS panel. My U2410 has it much worse so chill. Replace and regret, you could get something much worse!
1920x1080 is the same aspect ratio.
1280x720 is also the same ratio but would represent 4 times less pixels and that wouldn't look good on a 27inch screen.
Something ain't right here. Native res on my screen is 1920x1200, which is 1.6 ratio. If I set res to 1680x1050, which is the same 1.6 ratio everything looks blurred like crap. So, apparently it is not just the ration that makes it look good.
Resolution: 2560x1440What is the second native resolution on this thing?
Native resolution of this screen is 2560x1440, which is a 16:9 ratio (~1.78).
A 2560 x 1440 monitor should be able to display 1280 x 720 accurately without interpolation, and so will look about as good as a 1280 x 720 native monitor. (The only issue is whether a 2x2 grid of pixels at 2560 x 1440 looks clearer or less clear than a single pixel at 1280 x 720).This is well known with LCD panels. Anything but the native res (unless an exceptional scaler is used) generally looks unsharp and rubbish. No res will look as good as native.
What kills you at intermediate resolutions is that you end up with pixels that are, say, 1.5 monitor pixels wide, and there's no "good" way of displaying those (1 pixel is too thin, 2 pixels too wide, so you end up doing 1 pixel full and 1 pixel 50% blended, and then it looks blurry).
That's not an issue about the Dell's "native resolution", however. It will look the same as a 27" screen with native resolution 1280 x 720. In contrast, run the Dell at 1920 x 1080 (or whatever) and it will NOT look the same as a 27" screen with a native resolution of 1920 x 1080.The difference is your viewing distance doesn't change depending on your resolution. So say, 2ft being the optimal viewing distance for a 27" screen at 2560 x 1440 res does not mean 2ft is the optimal viewing distance for a 27" screen at 1280 x 720, it will be greater. You may have to be another 6ft back before the image appears the same.
The resolution 1.280 x 800 is exactly equivalent to half of the native resolution of 2.560 x 1.600 pixels and is not interpolated. As a result, this resolution is displayed in an absolutely sharp manner.
Whether you'd want to be close to a 27" screen at 1280 x 720 is another matter (and a reasonable point, but I'd have thought people can use their common sense here).
From a review of the 30" Dell:
Yes, 1280 x 720 isn't going to look great at 27", but the point is that because it's an integer ration of the full resolution, it will still look as good as a native 27" 1280 x 720 monitor.Yup, but you're still filling the same space with less information. Edge detail will be sharp but it still doesn't mean image quality on the whole will be as good as it's true 'native' resolution (which was my original point). It will only be perceptably the same from a greater distance, and as most people can't just upsticks with their keyboards, chairs and mice, and move 6ft across the room, I'de say it was a bit of a moot point anyway.
In contrast, displaying 1920 x 1080 is not going to look as good on the U2711 as it will on a 1920 x 1080 native display (at least for things like text and other things with lots of detail). Which is a fairly important point if you're expecting to often work at that resolution.
(One of the things people appreciated about the IBM T220/T221 was that its "2nd native resolution" was 1920 x 1200, so you could display full HD without interpolated scaling).
ooooh, trying to decide whether to get this over the U2410. I've got a 23" 1080P (TN) screen to pair with it, which will be useful for gaming, but what's putting me off the 27 incher is the performance hit I'll get at native. Knowing that I can drop down to 1280x720 without interpolation is always a blessing.
Shall be pairing whatever I go for with a 4870x2.
