I am also getting kicked after being in a server for more than tfice seconds.
PB init and no packet flow.
I have the latest PB updates so must be a problem server side maybe?
Same
didnt have this issue yesterday lolI am also getting kicked after being in a server for more than tfice seconds.
Samedidnt have this issue yesterday lol
I love my shotgun as medic blow em away brilliant fun
I found it really hard to kill people with the shotgun, I have the first two shotgun unlocks and it still takes a whole clip even at point blank range.
The assault class leads the way. I cant wait till I have the m16a1!
I still find it amazing that people moan about the Recon (Sniper) class. I play a mix of Recon and Engineer, and there are a few observations I have:
1) As Recon, I'm often killed from assault or engineers running around the map to find 'snipers'. Strangely, those matches are often the ones we win more easily because they're not actually going for the objectives.
2) As Recon, most of my points come from spotting or Mortar strikes. This helps me not be found so much, and is what the class should be doing. It's also not all guns & glory. as often you're watching a point where there's no action.
3) As Engineer, I'm rarely sniped. Probably less-so than as Recon. However, I'm generally using the RPG against vehicles or the repair tool, so I'm likely crouched out of sight trying to sort something.
The only way you're going to be sniped. generally, is running across an open battlefield, or sitting in a window camping (or perhaps you're the unlucky soul who was piloting the Apache until they had a bullet through the head). If you actually play your class role rather than run and gun across the map, you're not that likely to die so quickly.
If you want to moan, try it on those people who don't know how to 'spot', ignore the UAV flying around that's tearing the place up (sniper rifle is great for that), don't drop health or ammo and basically are more interested in K/D ratios (which they blame on 'snipers') than actually completing the objective and helping the team.
Yes, I do shoot people at long range. When they're capturing a flag, when they're stalking one of my team and when they're stupidly standing in the open doing nothing. That's my job. Next time you realise you're being followed because an orange tag appears behind you, you've likely been saved by Recon.
Hi guys
We got another server
Does someone want to give this a bash, I have just set it up and started it, cant test it as at work just now,
85.236.100.107:20367
Multiplay.co.uk :: Just shoot me now!
I just started it so there shouldnt be any PB issues
Let me know if there are any probs, Vent server to follow
Enjoy
Hi guys
Enjoy
