Is there a noticeable peformance boost from purchasing a second nvidia card to act solely as a physx device?
Thanks
Talk about being misinformed, Borderlands, Gears Of War, Brothers In Arms don't support physx in anyway at all...doh.
doesnt use nvida mate
There is a lot of games that support Physx. Some may not have the fully loaded features ala Batman, but there is Physx effects going on in games like Dragon Age, Mass Effect etc. While you may not get all the eye candy it can deliver, you will get faster frame rates which is what the OP was asking.
Stop typing crap...
Mass Effect is using PhysX but using the visual indicator shows CPU only, there may be a way to force it to use GPU as the engine internally supports it but I dunno, the performance gains would be minor anyhow as it only makes light use of physics primitives mostly.
