5870 vs 5970 bad company 2
I have 5870 paired with
E8400 (3.8 Ghz)
Abit IX 38 quad mobo
4 gig ram
I have not checked frames, i check them only when i notice they are slow.
I have not noticed single twitch or slowdown, in any situation.
Game @ 1920 x 1200 (no vsync)
anti alias @ 8x
aniso @ 16x
Antialias mode set to super sample AA
all forced through CCC
All settings in game set to highest level + HBAO
As for game being badly optimized, ********.
Recommended spec is quad CPU, and i run C2D
It either does not really need quad, or it is fantastically optimized for C2D
Word is that game likes high CPU clock.
Looks great too.
I've asked this in few thread :D in DX 11. is the AA working 100% for you.
Is the fences free from jaggy lines that you get with Less AA.
as via DX 10 MAX, i still get in places, jaggedy lines ?
Cheers.
Cheers.
I have not noticed any jaggies m8, but i will be back home later tonight and will check, and post a screenie
single 5870 is more then enough for bc2 even on dx 11 , i max out bc 2 on 260gtx dx 10
You max out on a 260. at what res ?
my single 275 via multiplayer, was far to stuttery for me.
when i added the 2nd one, it was 100 times better.. i think it was a dud anyway, as i't's died on me :( so maybe 5850 here i come.
Was gonna see what that femi could do. but will be far over priced i'm sure :p
I had close look for jaggies, there are none on the fences, but sometimes shadows could be sharper.
i tried taking scrennie, but standard prt scrn method does not work, i fraps only way to get screenie in bc2?
Yeah i noticed shadows on this game are abit crap :(
What setting in OCC do you have ?
I also tried print screen. which didn't work.
Cheers.
here are few scrennies taken with fraps
Looks exellent :)
Must be something up with DX 10 with this game then, as i get jaggies on mine maxed out via a GTX 275.
Is it running smooth then via multiplayer.. (i sound like a cracked record lol)
Looks like i will be getting one of these Asus 5850 :D
What res is that @ mate ?
Vsync on ?
Whats you're setup via the cards control panel ?
Be good to know what settings you have in there :)
Cheers.
Looks exellent :)
Vsync on ?
Cheers.
Res @ 1920 x 1200 (no vsync)
anti alias @ 8x
aniso @ 16x
rest of the spec
E8400 (3.8 Ghz)
4 gig ram
All in game settings on max with HBAO enabled.
I noticed you mentioned 5850, i am running 5870
anti alias @ 8x
aniso @ 16x
rest of the spec
E8400 (3.8 Ghz)
4 gig ram
Ok cool :)
Looks good thou :D
P.s.. what map is that first pic ? 4 tanks:D
mmm the game looks good just plays ****
Multiplayer is completely broken, but single player is as smooth as it can be, i managed to connect to multy game few times, and when you do it is also superbly smooth.
Highest frames i am getting are around 75-80 lowest never below 40.
Don't you get tearing with Vsync off then..
