NEW RANGE OF GIGABYTE AMD MOTHERBOARDS
17 Oct 2002
Stoke
Got a selection of new Gigabyte AMD motherboards starting from £48.99 Inc. VAT. These are ideal partners to our great value AMD CPUs that Fatboy launched recently (http://forums.overclockers.co.uk/showthread.php?t=18121214 and http://forums.overclockers.co.uk/showthread.php?t=18003270)
Gigabyte GA-MA78LM-S2 AMD 760G (Socket AM3/AM2+) DDR2 microATX Motherboard @ £48.99 inc VAT
The GA-MA78LM-S2H is based on the AMD 760G chipset and features an integrated ATI Radeon HD 3000 (DX10) graphics engine, supports AMD AM3 Phenom II/Phenom/Athlon processors, HyperTransport 3.0 technology links, DDR2 memory, PCI Express 2.0 graphics interface and more. With the innovative Gigabyte Easy Energy Saver technology, the GA-MA78LM-S2H is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- CPU: Phenom II/Athlon II/Phenom/Athlon/Sempron
- Chipset: AMD 760G / SB710
- System Bus: Up to 5200 MT/s HyperTransport 3.0 or 2000 MT/s for AM2 CPU
- Memory: 2x DDR2 DIMM 1200(OC) / 1066 / 800MHz (Max. 8GB)
- Integrated ATI Radeon HD 3000 GPU
- Expasion slots: 1x PCIe 2.0 x16 Slot, 1x PCIe x1 Slot & 2x PCI Slots
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 4x SATA 3Gb/s (RAID 0, 1 & 10)
- LAN: RTL8111D Gigabit LAN
- Audio: ALC888B 8-channel High Definition Audio CODEC
- 12x USB 2.0
- 1x PS/2 COMBO (Keyboard & Mouse)
- 1x DVI
- 1x D-SUB
Only £48.99 inc VAT.
ORDER NOW
Gigabyte GA-770T-USB3 AMD 770 (Socket AM3) PCI-Express DDR3 Motherboard @ £75.99 inc VAT
The GA-770T-USB3 introduces revolutionary Gigabyte Ultra Durable 3 technology on the latest AMD socket AM3 platform and features a 2oz copper PCB that helps to reduce system temperature and dramatically enhance the performance. Based on the AMD 770 chipset, the GA-770T-USB3 supports the new generation of 45nm AMD AM3 Phenom II/Athlon II processors, integrated DDR3 memory controller, HyperTransport 3.0 technology links and PCI Express 2.0 graphics interface support. With the innovative Gigabyte Easy Energy Saver technology, the GA-770T-USB3 is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- CPU: AMD Phenom II/Athlon II (Socket AM3)
- Chipset: AMD 770 / SB710
- Memory: 4x DDR3 DIMM 1666(OC) / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Expasion slots: 1x PCIe 2.0 x16 Slots, 4x PCIe x1 Slot & 2x PCI Slots
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66 & 6x SATA 3Gb/s (RAID 0, 1 and 10)
- Audio: ALC888 8-channel High Definition Audio CODEC
- 12x USB 2.0
- 2x USB 3.0/2.0
- 3x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
- 1x S/PDIF Out (Optical)
- 1x S/PDIF Out (Coaxial)
Only £75.99 inc VAT.
ORDER NOW
Gigabyte GA-790XT-USB3 AMD 790X (Socket AM3) PCI-Express DDR3 Motherboard @ £102.99 inc VAT
The GA-790XT-USB3 is based on the AMD 790X chipset and supports new generation 45nm AMD AM3 Phenom II and Athlon II processors, integrated DDR3 memory controller, HyperTransport 3.0 technology links and 2x PCI Express 2.0 graphics cards with ATI CrossFireX support. With the latest innovative Gigabyte USB 3.0/3X USB power & Easy Energy Saver technology, the GA-790XT-USB3 is able to provide amazingly fast data transfer via USB 3.0 connectors, also to reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- Chipset: AMD 790X / SB750
- Memory: 4x DDR3 DIMM 1866(OC) / 1333 / 1066 MHz (Max. 16GB) / Dual Channel
- Expasion slots: 2x PCIe 2.0 x16 Slots, 2x PCIe x1 Slot & 3x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 6x SATA 3Gb/s (RAID 0, 1, 5 and 10) & 2x eSATA 3Gb/s
- Audio: ALC889 8-channel High Definition Audio CODEC
- 10x USB 2.0
- 2x USB 3.0/2.0
- 3x IEEE 1394a
- 1x PS/2 Keyboard
- 1x PS/2 Mouse
Only £102.99 inc VAT.
ORDER NOW
Gigabyte GA-890GPA-UD3H AMD 890GX (Socket AM3) PCI-Express DDR3 Motherboard @ £109.99 inc VAT
The 890GPA-UD3H motherboard is designed to offer a stable, high-speed platform for delivering amazingly fast data transfer via Gigabyte's revolutionary Ultra Durable 3 Classic technology with 2oz copper PCB and latest Gigabyte 333 onboard acceleration technologies (USB 3.0 / SATA3 6Gbs / 3x USB Power). Based on AMD's 890GX chipset, the 890GPA-UD3H supports the latest 45nm AMD AM3 Phenom II/Athlon II processors, integrated DDR3 memory controller, HyperTransport 3.0 technology links and dual PCI Express 2.0 graphics interfaces for ATI CrossFireX/ATI Hybrid CrossFireX support. With the innovative Gigabyte Easy Energy Saver technology, the 890GPA-UD3H is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- CPU: AMD Phenom II/Athlon II/Sempron 100 Series Processors (Socket AM3)
- Chipset: AMD 890GX / SB850
- Integrated ATI Radeon HD 4290 GPU
- Expasion slots: 2x PCIe 2.0 x16 Slots, 3x PCIe x1 Slot & 2x PCI Slots (Supports ATI CrossFireX Technology)
- Storage: 1x Floppy, 1x Ultra DMA 133/100/66, 6x SATA 6Gb/s (RAID 0, 1, 5 and 10) & 2x SATA 3Gb/s (RAID 0 and 1)
- Audio: ALC892 8-channel High Definition Audio CODEC
- 14x USB 2.0
- 2x USB 3.0/2.0
- 3x IEEE 1394a
- 1x HDMI
- 1x DVI
- 1x D-SUB
Only £109.99 inc VAT.
ORDER NOW
The first mobo descriptions says it has 4 DDR2 slots, but the pic only shows 2? Is this a typo or wrong picture? Thanks!
