Intel or corsair ssd?
26 Jan 2009
West Midlands
alright guys, im considering getting either
Corsair Extreme X64 64GB 2.5" SATA-II Solid State Hard Drive (CMFSSD-64D1)
or
Intel X25-M Mainstream 80GB 2.5" SATA-II Solid State Hard Drive (SSDSA2MH080G2C1)
which would be better?
will just be using it for os and a game, then other files on a different HD
cant find a comparision chart of them anywhere read/write speeds
thanks
I'd suggest the game(s) on HDD and apps on the SSD. They will see much more performance gain than games. I have a few games on SDD and TBH it makes no difference that I've noticed vs being on a VelociRaptor previously. Oh, and get the Intel!
Plenty of comparison charts out there. Google it, but here's one to start off...
http://www.tomshardware.co.uk/charts/2009-flash-ssd-charts/Desktop-Performance,938.html
Doesn't look like it's been updated for the new Corsairs but you can see the X25-M drives are up there with the best of them. You can drop down various other benchmarks from the menu bar.
thanks so might get the intel then
i can get the corsair one cheaper than the intel but the intel drive is better right?
