- 5 Jan 2007
why are you running 16AA isnt that a killer for fps? what res do you run it at?
Sorry that was a typo, should have been AF, im running x8 AA, have tried lowering it to though as mentioned. Res is 1920 x 1200
Runs OK on my 4870 @ 1920x1080 I used to have a bit of judder but turning up anti-aliasing from 1x to 8X solved that, average 40-55fps![]()
Runs fine on a C2D e8400 at stock with a 4890 also stock. 1920x1080 all high. Seems a lot of peeps having performance issues on better hardware than mine...
I did a very small core scaling performance analysis of bc2 using my phenom setup:
http://forums.overclockers.co.uk/showpost.php?p=16145516&postcount=64
