err... how can they run a dx 11 bennch with cards that dont support it?![]()
Brave man who turns up the volts on the 480
LOL, 50% faster, and it's gonna need it by the looks of things..muhahaha
this is ocuk for the past few months
You'd deff. get ~900MHz on good cores... the problem is the number of good cores is likely to be a very very low proportion.
Here are some very unqualified assumptions about 4x0 overclocking. This is based purely on the fact that both 57xx, 58xx & 4x0 use the same 40nm process.
57xx is half the size of 58xx, but both GPU will overclock to ~1000MHz with voltage increases (1.25 to 1.35v). After 1000MHz, heat seems to be the limiting factor. Several people with custom (water) cooling can hit 1100MHz.
Assuming Fermi has the same voltage tweak functionality, and assuming the reference cooling is sufficient (big assumptions), it is not unreasonable to expect ~900MHz out of good cores. We also need to consider the memory. NVidia use very low clocks for their GDDR5. If they use the same IC's as ATI (Samsung & Hynix), we should see "easy" 20-30% headroom for overclocks.
So, theoretically Fermi may be a complete monster when overclocked. Perhaps the reason NVidia have released the 480 with only 480 SP's is because they know they have a monster, and are holding the 512 SP version back for ATI's response.
Of course, this could all be complete rubbish and Fermn may be a lemon.
What £30 for some realistic physics effects?, sounds a reasonable deal to me - or effectively nothing extra for me as I already have a decent nVidia card setup.
