Fermi has 480 shaders, 675MHz+ clock
Once devs start using multi-threaded CPU PhysX properly we shouldn't really need a nvidia card present to get decent performance.
http://physxinfo.com/news/2390/new-physx-fluidmark-1-2-first-tests/
Of course in a game you wouldn't be able to use 100% of a CPU for PhysX but most games barely use more than 2 cores, which on an i7 or hex core system leaves plenty of available CPU power to run multi-threaded physX too.
interesting, hope this happens.
also got me thinking with quad and new 6 cores could someone write code to get the current gfx based physx stuff from games onto CPU so even an amd card can use it ?
We wont get multi threaded Physx because Nvidia drivers dont allow it. They are keeping Physx locked to function exclusively on Nvidia hardware.
Even with a fully threaded CPU implementation - your limited on the number of soft body, fluid effects, etc. you can run... a highly specialised solver can manage physics on 2000-4000 RBs and a handful of ragdolls - but a general purpose physics API will hit the ceiling at about 200-300 on a 3gig quad core and maybe 500 or so on a hyper threading i7 and thats not even including other effects.
Sure CPUs can manage anything we've seen in games so far, even those using GPU/hardware physics but hardware phyiscs is capable of so much more.
Everything has a limit as long as its got enough to do the job that its intended for then that's all that matters.
