SETI@home News Vol. 97
The paste that comes with it I wiped off and never used so I don't know if its any good but you can try it if you feel temps are not ideal change it for some MX3 or other gear
I will go with the voice of experience and wipe the paste of the h50 and use the mx3...small s shape and spread with whats left of my credit card?
I spotted you waving your e-willy in graphics last night "i'll take 3" i never felt so poor lol
All will be revealed on Friday.... Bu I fear if you are easily dissapointed just stay off the net for that day
Hmmm would appreciate some input on this one peeps
1. power supply unit
2. leads from power unit
I have plugged in the cable for mobo and have these cables left 2 x 8 pin and 1x8pin connected to a 6 pin.
My graphics card has 2 x 6 pin slots please could someone tell me by looking at the pic of the power supply rear which/how to connect my graphics card as there are a few with different voltages....dont want to blow myself up now do i ;-)
Am also stuck with fans have changed the rear exhaust fan to inflow for the h50 radiator not sure which header to connect the h50 -cpu fan? Then theres the small matter of the 3 exhaust fans at top of the case and the two at the bottom, trust me i have tried the usual searches and cant seem to find a clear resolve...any ideas greatfully accepted thanks all.
Right Tox....
VGA Card Connectors: there are 6 pins (3 off) and 8 pins (3 off) - V3 & V4 connections on your PSU
Use the 6 pin connectors for your GPU (all the leads that came with the PSU should be colour coded for the PSU i.e. red to red & purple to purple.
Use one red (6 pin) & one purple (6 pin) to power your GPU.
Toxic.....
Is it a Thermaltake 1500w Toughpower PSU?
As I thought all the vga connections on the 1500w PSU were red?
(Mind you, my Corsair HX 1000w has different coloured connections than those pictured on net)
