What do you mean by this? Just jump straight back through?If you jump through into a gatecamp, crashing back on the gate is usually the best COA after your session timer has changed.
The gatecamp where you're most likely to die is a drag bubble camp... Those things suck![]()
Yes, although unless you are in an interceptor, you'll likely die
Can you explain to a noob what bubble camps and drag bubble camps are please?
Bubble camp - interdiction bubble placed directly on the gate to stop people warping off who jump through, or stop people warping to zero on the gate. Drag bubble camp - interdiction bubble placed on a direct line gate to gate 50km or so behind the gate you are flying to. This pulls you out of warp at the bubble, and even if you get out of the bubble, you have 50km to go to the gate before jumping though
If you panic, hit MWD to the gate, even if you do make it back you will possibly be prevented from jumping by the time limit between session changes (session timer i.e jumping between systems etc.) so hold your cloak to wait out the timer, MWD under overload and spam the jump button.
How poor are you at flying ceptors. A good ceptor can get from cloak to a gate in <2 seconds. Most ships can't even lock and fire a volley in this time so you jump through and should be aligned and in warp on the other side before their fleet can even click the jump button.
Yet another thing I never knew. Eve is nearly too deep for its own good at times![]()
read my statement again![]()
I've managed to get myself on the killboard a couple of times now,but im afraid its only for taking out some SBUs. lol.
EveGate alpha-test is up, currently connected to Singularity but worth taking a look....
http://test.evegate.com
2 days to my eve-birthday![]()
Link:http://www.gmbar.com/mmorpg-1821.htmlFor the unfamiliar, EVE Gate is the renamed New Eden feature, which in turn is a rename of the COSMOS feature. But what is EVE Gate exactly? Well, according to CCP it will be your "gate into EVE." D'uh! EVE Gate will allow players to interact with EVE through any ordinary web browser. The feature has been designed with scalability in mind from the get-go, though initial offerings will be limited to communication and collaboration tools, including access to in-game mail and a calendar. Players will also be able to use EVE Gate to post updates for players, corporations, and alliances.
Beginning tomorrow, EVE players will able to access the very first public iteration of EVE Gate, which will be limited in features. The aim of the test is to essentially stress the hardware in order to find bottlenecks and weaknesses before the system goes live in May.
"No, we're not hiring the Hanson brothers to deal with RMT threats. As there is no one better at beating up targets than EVE pilots, we thought we'd enlist your talents in slapping EVE Gate into shape.
As CCP t0rfifrans outlined on his blog introducingTyrannis, we will be delivering the very first iteration of EVE Gate in the upcoming expansion. It is my task to oversee the technical direction of the Web side of things with EVE Gate, and I wanted to take the opportunity to announce a public ¡¡ãAlpha¡¡À test we are planning for EVE Gate and the steps we are taking to make sure we have a very sound foundation to build upon. What we don't want to do is just turn all the traffic completely on the first day and pray it doesn't break under load. Instead we plan a measured approach that will make sure we have a solid architecture and enough hardware in place."
Read the full Dev Blog to get more additional details.
Thanks for all the info on bubbles guys. Very informative.
I'll still be carebearing for a bit yet but I'm soaking up all this info while I'm doing it.
Edit: One more thing. Can you see the bubbles or do they just show up on a scanner?
