Dont get those ssd's you will be much better off getting a good 80gb drive such as the Intel x-25m...the value ones are good but the x-25m are quality.......Well i think im right in saying that as long as you use 'TRIM' then you wont have any problems.....
I'll look into it
Used up my last drop after lapping my Q6600^
blimey! Do it!
Not sure you need the artic paste, unless you got some heatsink you not mentioned.
q.q
and yes it is slightly cheaper.
