uTorrent kills my internet
Caporegime
6 Dec 2005
Birmingham
Trying to download some hefty face and logo packs for FM 2010, and after about 5-10 downloading my internet keeps cutting out.
Never happened before and it doesn't happen when I'm using usenet. :confused:
Any settings I should be checking etc?
Do you have a rubbish router like a BeBox or something? Some routers are terrible at handling lots of connections (which a torrent needs to have open).
Have you limited your upload at all?
I usually have it at 10 kb/s and don't have any problems. Will put it up a bit.
It's a Zyxel.
Limit the number of connections, a lot of consumer-grade routers crash as they can't handle the volume of connections they have to maintain.
I'll give it a go.
No no, keep the upload at 10 that should be fine, it'll be the connections thats the problem I reckon as has been said, some routers just can't handle it.
