- 27 Nov 2008
I was using a Samsung HM160HI HDD. Can anyone please suggest a replacement that wont set me back a massive amount! Thanks
Patrick
Patrick
Until I saw you mention cost I was going to say an SSD, massive improvement on a laptop and worth every penny but only if you can afford it...
Your old drive is a 5,400rpm drive I see. Depending on the age of your laptop (if it's newer go with SSD) I'd recommend getting a 7,200rpm drive. I did this for my DELL for under £50 and now it's like using a desktop machine. The response time is much better and it didn't cost me too much to do.
http://www.overclockers.co.uk/showproduct.php?prodid=HD-224-WD&groupid=701&catid=14&subcat=896 is a good example of one of these drives. I have the 320GB version, but there is also a 160GB version for cheaper.
