The next ATI chip will be bigger and hotter, much like the current GF100, if they have to use the same 40nm process.
Nvida will have a very tweaked respin of the GF100 architecture within 6 months.
Problem is - on 40nm the GF100 even with a very tweaked respin isn't going to yeild massive increases in performance or reduced power/heat on the high end parts... the design really really needs to be on the right process not shoe horned onto something it was never designed for.
The only thing they are likely to achieve from tweaked respins is more economical low and mid range parts, with somewhat reduced power needs/heat output. (I kinda hold out hope for a "GTX260" style part that has massive OCing potential)
ATI has its own problems tho, doubling up the numbers on evergreen to go to next gen would give a much smaller performance increase than the 4870->5870 jump.
Though you did say the same thing quite a lot when it came to 4800s > 5800s, which turned out to be incorrect.
We simply don't know how they'll perform and speculating in such a way, as you should now be aware of, doesn't mean much.
Do I bother getting a 5870 now, when this refresh will be hitting before the end of the year.
Ignoring all the anti-NV BS from the raving mad lunatic, this is not good news for anyone really.
Source?
Source?
But surely improving the design to work around the transistor issues reduces the need to overvolt the chip to fix slightly broken transitors, thus reducing the power requirements. Likewise for clockspeed, a better quality chip will allow a higher frequency for the same voltage/power/heat production.A tweaked Fermi will have better yields, NOT better performance, the via's and spacing out fixes for 40nm increase yields, it doesn't reduce power, it doesn't increase possible speeds, it fixes yields and thats it.
Because if it's faster and on the same process it has to be?
And if they can increase yield significantly then they also have the option of either producing a better binned part or lowering the voltage/TDP and throwing away/lower binning GPUs that are marginal (but that they are now forced to make work due to the incredibly low yields).
I'm not saying this will happen, overcoming the large die-size issue is a major problem, but there are performance improvements that can be made.
