 - 1 Jul 2007
Thinking of building one out of perspex or the only one I can find in the material finish I want is plexiglass. (high gloss white)
Thing is that it would only be attached via two walls (corner, one length (1700mm of desk one width of desk 700mm) and that it would be running window height, which means windows sills would be in the direct way of attaching it to the wall. was thinking of somesort of L shaped blocks of wood that i could sit on, which may also allow gaps for cables to run down.
I also want a "floating" set of drawers attached.
What sort of thickness of sheeting should I be looking at? The stuff I've found is only 6mm thick:
http://www.plexiglas-shop.com/GB/en/cutter.htm?$product=3q4bp8hz18m~p&comeFrom=detail
Would also need it bent round to form the drawer unit as I want it to appear to be made from one sheet.
any tips, other forums to visit etc?
