Farm Simulator 2009
lol out of seriousness I might get it if it scores over 6 out of 10 hay im normally 7 out of 10 here :P
Definitely thinking of getting this. Shame it's only arable farming though and not animals - they could have included cows for dairy and sheep for wool if sensitive about meat farming.
Hey, hang on...another idea for a new game... Sheepdog Simulator!
Bit of an update:
Getting on well with it currently, purchased a new tractor, and about to purchase a new combine 'arvester :D
It's a little difficult to understand from the off, but you just work your way into it. I really disliked how slow your first tractor is, and I was glad when I purchased a new one.
The 'missions' are quite cool, and help you understand the basics of the game.
Top tip:
you can attach more then one tool to your tractor at any time, this means that you can do things like this:
I have a seed spreader on the front and a sprayer on the back, meaning i can do 2x as much work in one sweep :D
um... but that drill is runnning backwards? surely althought the game allows it, its wrong and should upset you.
i personnelly use a lemkin solatair 12 to drill with and a lemkin 14m culivater behind big bud. have to run to run two lexion 600 with the v1200 vario headers on to keep up!
Tbh im pretty much organic what with the growth rate in the game hardley get a chance to spray, 2 combines going 24hrs non stop. will post some pics in a minute
Bale stack, and the auto stacker i use to lug them in with
The baler and the beast of a tractor
Big Bud pulling a lemkin 14m
2 combines, both lexion 600, one in cat clours with a 20m header, the other with claas new v1200 cario header.
Internal pic of the Cat, can see claas in the distance
hmm, seems to work, though time will tell if it planted the seeds.
Purchased the Fendt 614 with front loader (as seen on my previous post) and I now have the Fendt 9460 combine, working towards the Fendt 936 (black) and have $189k of the $220k I need to buy it :D
I upgraded my cutter to the Fendt 7700 and purchased a medium tipper, I do all the work myself to keep my capital up (is it expensive to hire?)
Love your setup gbradders123, ace! How are you finding the modded vehicles ? Are the easy to install and good quality ? What difficulty level did you pick ?(I went for easy :o :p )
im on medium i think, once you get a decent combine, money is not a problem,
the mos genrally work fine, easy to install, some you ahve to click on an exe, others you ahve to drag the zip folder into you mod folder, which is in my games in my documents.
mods are here: http://new.ls-uk.info/
ahh, cool. Many thanks for that :)
I'll look into the site and see what's available. :D
