PC BUILD VERSION 3.47596 MAKE IV
Dude I seriously think you should read about on this forum a bit more and look at benchmarks and reviews of products a bit mroe you seem to be just throwing cash away on things that are very OTT.
What? Like your OTT motherboard, psu and case.
You haven't thought any of this through have you?
That case is over the top? But I've gone through so many cases and none of them match up to this one in term of features at this price.
No I haven't looked at them thoroughly as I don't exactly know what's good what's not. I just see something that's pricey and automatically think its better than the cheaper ones. I guess that's what I do when I don't have knowledge about computer components.
You could get a case £20 cheaper and it will be much better. Corsair 800D Lovely case its one that you would just like to jizz over but wont because that would be weird :L
How do I see benchmarks of products. But if I might be looking to do 5890's in crossfire, I might even go quad?
Okay, I'm going to watch a review of the 800D and watch the review of the Lian Li again and compare what they say.
5890 does not exist. 5850, 5870 and 5970 exist and if you mean 5970 maximum is x3 corssfire and thats OTT!!!!!!!!!!
The only way to abuse that amount of power is to have 3 Dell 30" Ultrasharp Monitors at highest resolution using eye finity :L
Okay I understand that. May I ask what is the point of crossfire/sli then. For example why have 2 x 5850's when you can get on 1 x 5870 which equals two 5850's?
Okay I understand that. May I ask what is the point of crossfire/sli then. For example why had 2 x 5850's when you can get on 1 x 5870 which equals two 5850's?
Sigh...
2x 5850's would kick a single 5870's ass.
But 5850 x2 is equal to a 5970.
May I ask what Monitor and reolution you have then I could spec you the correct GPU for you.
