Well, obviously they think some people will use 2 -6 monitors, this isn't supposed to perform better than a normal 5870, its for people with more monitors and higher resolutions as a result, hence the extra ram.
I use two monitors but a normal one is perfectly fine for that.
Am I seeing this right? The 5870 is now the same price as the GTX 480? What do the ATI fanboys say about this????
no point in 6 screens (for gaming) if doing 2x3, you'll still hame the same fov except bezel in the way. I think [H]s demo of that is clear.
3x1 you have a great wide fov and nothing in the way of the crosshair. 5x1 in portrait would work too.
i want more than 1gb, for EFLC release
£300 to be honest, 5870s should be £240 and 5850s should be £170.
Does episodes from Liberty City require more than 1gb of ram? I would have thought it'd have the same requirements as GTA IV
Interesting thing to note with these is you ideally need 2 in CF to really get the most out of the cards. For 3 monitors using AA, these are the best bet over the 1gb version but if you have 1/2 monitors, avoid this version. The larger frame buffer due to the 2gb of ram actually makes you lose FPS at lower resolutions. This version of the card only starts to be worth its price when at the 3 monitor eyefinity setup.
yes true.
the main thing you need is the 2gb version of the 5850 with some overclocking running 3 thin bezel monitors
i already have the 3 thin bezel monitors but iam waiting for the right card![]()
Yeah would be nice to see a 5850 version with 2gb and just 3 outputs on it to be honest at a better price tag. Would be a more interesting card in my opinion.
