Better safe than sorry dude...
View the circuit. A £5 power strip protector selling in a grocery store is the same protector circuit selling with expensive paint for £100 from Monster Cable. Same circuits. Numeric specs are even similar. Both make same protection claims. One is the actual costs plus a minor profit. Monster has a long history of identifying scams, then selling the same product for extreme profits.Because the cheap surge protects are just that, cheap. There was a test done a few years back which proved most did very little and could only take one proper surge before they became nothing more than a standard 4-way.
No damage from direct lightning strikes is routine. Again, the numbers. Lightning is typically 20,000 amps. So the minimal 'whole house' protector is 50,000 amps. Sufficient to earth a direct lightning strike - and remain functional. That is what any and every effective protector must do. Earth any surge and remain functional.Perhaps we have to clarify the extra energy being dealt with here: A lightning strike is rare. Lots of energy, it would almost certainly destroy the electronics, and a regular protector would not help. Surges from poor power distribution/faults? Surges from bad equipment IN the house? Is there any situation where a plug in protector is going to be of use if it's just connected to a PC?
Spend £20 or £80 per appiiance for a plug-in protector that does not claim protection AND sometimes can even contribute to appliance damage.surge protection cheaper than new pc
Lighting isn't your only worry, things like power cuts when it goes off or comes back on can cause a big surge. or just general surges with dodgy wiring. most houses have fuses that will stop this anyway, so there is nothing to worry about mostly.
Speaking of dodgy wiring, when we turn our kettle on downstairs the lights flicker and the microwave clock resets
New house builds using rubbish electricians ***
If a heater was creating a destructive surge, where is the long list of destroyed appliances? That surge was confronting every appliance on the same breaker box. Surges that might harm dimmer switches and digital clocks must be too small to harm computers. So why was that computer's power supply so inferior? Is that heater creating 1000 volt spikes? Even Intel ATX specs say it must withstand 1000 volt spikes without damage.This is why I use spike protectors. I had a heater in my room, and when it tripped it took my PSU out, I don't use the heater anymore. However i'm confused now if surge protectors are helping.
I also don't understand the fuss about earth, in UK we have earth plugs, and the surge protector should just earth down this.
I had a system go boom about 8 years ago, used surge protectors since and it's been fine.
Why are you using near-zero protection? Read its numbers. Near zero. But just enough above zero so that a UPS can claim surge protection in its sales brochure. If you need protection, then why are you using a UPS that claims only near-zero protection? Because so many misguided peers - a majority - recommend it? Same number of people also knew Saddam had WMDs.But since then, I have decided to not cut corners, and Im running off a Galatrek UPS
Why are you using near-zero protection?.
Good. Then you have spec numbers from that UPS manufacturer that lists protection from each type of surge. Post those numbers. Show me which number actually defines what protection. Post each specific numbers that shows effective protection from surges. If you know, then you can provide the reason why you know. Post the manufacturer specification numbers for protection from each type of surge.For many reasons Im going to ignore that post.
Main reasons:-
Considering a 4-way extension with surge protector is about £2 more than one without, I think it's plain stupid not to.
It might help, it might not, but for £2 there's no reason not to.
