Surely a drum can be taken apart and a new one fitted. You just need someone to bring round a big blowtorch in back of a van
Don't think that'll hold up too well on the dual carriageway.Jack it up onto mcdonalds trays and drag /tow it
Apparently they've never needed to use one.Don't the garage have a recovery vehicle to take your car in?
No need for grinding, hammering, blowtorching(!) or cutting though. A disk/gear puller will have it off in 2 minutes.
http://www.timguydesigns.co.uk/tim/pics/disk-puller.jpg
About £20 from Halfords.
http://www.halfords.com/webapp/wcs/..._productId_172526_langId_-1_categoryId_165469
As you say - you're not clued up mechanically. Even if you got the drum off, what lies underneath would be meaningless to you.Well, the mechanic tried, failed and said that the only way to get it off would be a grinder?
So, is the £20 worth it, or am I not going to get it off either?
The lining will have come off the shoe, spun round and jammed between teh brake cylinder or the other shoe and the drum.
slacken the handbrake cable as far as it'll go and set about it with a couple of levers and rotate it if you can. I've never had to grind a drum off, thats just ignorant. Patience and technique will get it off.
Can the hub be unbolted from the axle? May be easier to remove the whole assembly and get it on a bench.
