OVERCLOCKED INTEL CORE i7 930 @ 4.20GHz X58A-UD7 BUNDLE NOW AVAILABLE
Status
Not open for further replies.
19 May 2005
New *OVERCLOCKED* Intel Core i7 930 2.80GHz @ 4.20GHz Max / Gigabyte GA-X58A-UD7 Intel X58 DDR3 Motherboard Bundle now available taking full advantage of the latest Gigabyte X58A-UD7 motherboard pushing the Intel i7 930 to a lightening fast 4.2GHz. This bundle offers superb performance now and is fully future-proofed thanks to its full SATA 3.0 and USB 3.0 compatibility
*OVERCLOCKED* Intel Core i7 930 2.80GHz @ 4.20GHz Max / Gigabyte GA-X58A-UD7 Intel X58 DDR3 Motherboard / Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel DDR3 Bundle @ £749.99 inc VAT
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast. Available with three different levels of overclock your ideal bundle is just one option away.
We take full advantage of the latest Gigabyte X58A-UD7 motherboard pushing the Intel i7 930 to a lightening fast 4.2GHz. This bundle offers superb performance now and is fully future-proofed thanks to its full SATA 3.0 and USB 3.0 compatibility
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X Intel Core i7 930 2.80GHz overclocked up to 4.20GHz!
1 X Gigabyte GA-X58A-UD7 Intel X58 (Socket 1366) DDR3 Motherboard
1 X Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel Memory
1 X Prolimatech Megahalems Performance CPU Cooler (Socket 775/1366)
1 X Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM
1 X Arctic Cooling MX-3 Thermal Compound
Note - This bundle will take upto 4 working days to complete and be tested. This is due to the fact not all processors will run sustainably at 4.20 Ghz and chip yields will vary week to week.
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours.
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced.
Note - The bundle operates above manufacturer specifications, as such it requires a quality power supply to operate with guaranteed stability. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range.
Note - Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £749.99 inc VAT.
ORDER NOW
Me and my cousin's husband are buying an overclocked bundle sometimes within the next couple of months. I'm more of the researcher so he's asked me to find out if this bundle will be updated anytime soon, so we're not disappointed if its outdated the next day :)
At this time its hard to say how fast our bundles will change due to new hardware coming out all the time, the only thing i can tell you is this bundle is very current, you'll be getting a 4.00GHz Overclock for the hardware price of 2.80GHz
no program as of yet is designed to beat this performance, but having that extra power/performance this bundle offers you'll be able to see the increase within games and aplications dramaticaly, extra performance helps with everything you do on a PC and at this point I dont think you'll be outdated straight away :)
This bundle does offer the chance for upgrades later on to :)
Ok, well its not particularly important anyway. I'm just cautious because i bought a Q6600 and the mobo a few months before the i7's were released and i wish i'd waited. Obviously intel arent going to release ane i7 any time soon as they've just announced the 930.
FYI, i'm going to be using this for 3DS max rendering, you wouldnt happen to have seen any benchmark tests comparing the q6600 with the new i7 on rendering speeds?
thanks
the 930 is about 30% faster in non-gaming benchmarks, and the 920 can usually oc higher than the Q6600 overall due to hyper-threading the i7 is the best choice for rendering.
I am really interested in this bundle and I think its very reasonably priced when you look at the price for each of the individual components - is it possible to go for this bundle but change the cooling to the H50 water cooled or maybe the all black version of the megahelems cooler?
If you call our sales team on 0871 200 5052 they will be able to change this for you while placing the order
Whats the fastest this package can be overclocked and rock solid if you fill all 6 ram slots (ie 12gb)?
This depends on all the components together we are able to add an overclock to bundles with more memory added but this overclock would be significantly smaller due to the memory controller and more voltage needed to support the overclock, If you call our sales team and requested this action when you placed an order we would be able to try our best to get a really good overclock for you.
I have made this exact same combination ( cpu board and ram ) and im having a nightmare getting it to run stable at even default settings.
Sometimes the board only detects 4gb of ram and at 1600speeds the ram fails prime 95 after a few mins. Im suspecting that this ram is not compatible with this board! ( each stick tests fine individually ).
BIOS Settings
Hi,
I bought this system from you a long time ago and recently the battery needed replacing on the motherboard and somehow the BIOS settings got lost.
Do you keep a record of these settings and if so, could you somehow e-mail them to me.
Regards,
Alan.
Now this is a blast from the past!!
I had a 920 @ 4Ghz, only needed upgrading recently and lets be honest, it didn't really need upgrading. 6 years and in games it was still up there performing with the best of todays hardware, only slowed down when using SLI.
Status
