- 19 May 2005
New *OVERCLOCKED* Intel Core i7 930 2.80GHz @ 4.20GHz Max / Gigabyte GA-X58A-UD7 Intel X58 DDR3 Motherboard Bundle now available taking full advantage of the latest Gigabyte X58A-UD7 motherboard pushing the Intel i7 930 to a lightening fast 4.2GHz. This bundle offers superb performance now and is fully future-proofed thanks to its full SATA 3.0 and USB 3.0 compatibility
*OVERCLOCKED* Intel Core i7 930 2.80GHz @ 4.20GHz Max / Gigabyte GA-X58A-UD7 Intel X58 DDR3 Motherboard / Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel DDR3 Bundle @ £749.99 inc VAT
Representing the cream of the crop of today's bleeding edge performance hardware, OcUK's 'Extreme Bundles' are selected to satisfy the needs of the most demanding enthusiast. Available with three different levels of overclock your ideal bundle is just one option away.
We take full advantage of the latest Gigabyte X58A-UD7 motherboard pushing the Intel i7 930 to a lightening fast 4.2GHz. This bundle offers superb performance now and is fully future-proofed thanks to its full SATA 3.0 and USB 3.0 compatibility
OcUK Overclocked Bundles feature carefully selected components tested to assure compatability & stability, guaranteeing the integrity of the overclock.
We worry about the fiddling and tweaking, you just enjoy the performance.
This bundle ships pre-built and pre-overclocked direct from our Technical Department. All you need to do is attach the CPU cooler and power it up.
- Maximum Speed
- Maximum Stability
- Maximum Compatibility
- Maximum Overclocking
This Bundle contains the following components:
1 X Intel Core i7 930 2.80GHz overclocked up to 4.20GHz!
1 X Gigabyte GA-X58A-UD7 Intel X58 (Socket 1366) DDR3 Motherboard
1 X Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel Memory
1 X Prolimatech Megahalems Performance CPU Cooler (Socket 775/1366)
1 X Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM
1 X Arctic Cooling MX-3 Thermal Compound
Note - This bundle will take upto 4 working days to complete and be tested. This is due to the fact not all processors will run sustainably at 4.20 Ghz and chip yields will vary week to week.
Note - All Bundles are built and installed on demand and usually ship within 48 hours of the order being placed. During exceptionally busy periods this time can increase by 48 hours.
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced.
Note - The bundle operates above manufacturer specifications, as such it requires a quality power supply to operate with guaranteed stability. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range.
Note - Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Only £749.99 inc VAT.
ORDER NOW
- Maximum Speed
- Maximum Stability
ORDER NOW
