then there is the gpu which puts out a lot less than an overclocked i7
Really? I always thought GPU's where meant to produce quite a lot more heat?
*although i've not really looked into water cooling a lot, last time i was thinking of doing it the rads etc where sort of rare and expensive
I did find though that a garden hose connector from B&Q perfectly connects a 1" ID car radiator hose and 1/5" id tubing if you put the car hose on the outside of the part the plastic hose socket usually goes inside ^_^
Sadly though this was after most car rads stopped being copper and became aluminium and plastic
OcUK of course
Ocuk don't sell those fans do they?
Excellent photos and cable management though
Must have taken a long time re braiding the psu cables
