steam 4 pack comes to 22
So helpful, unfortunately I don't have a quad split personality
didnt work for me at all tonight :/is anyone else havign problems with q internmitantly spotting people now?
Found a nice way of getting some good kill/death ratios. You just need to be playing a load of idiots.
Found a sniper camped in Panama canal, was just about to take his head off when his team mate spawned on him, was a medic so I quickly changed target and killed the medic. Then another team member spawned on him, so again I shot the team member leaving the sniper happily taking pot shots through his scope, totally oblivious to his mates dying when spawning on him.
14 kills in just over a minute, had I not got hit by a fluke Gustav I'm quite sure I could have done the same thing all match.. are some people really that thick?!?!
But presumably you have the mental capacity to find 3 people to sell the others to...
Played a fair few rounds last night on the OcUK server right up till almost 1am, I was <Hazy> for those that where on last night picked up a few tags only one I can remember where UV's.
I normally play recon but got all the unlocks so moved on to assault last night and was surprised that a lot of people who play recon don't use the motion sensors, found my self defending a mcon or taking a flag not knowing if whole squads where sneaking up on me. Can't wait till i can unlock a decent close quarter gun I can use for recon.
I assume there would be no problem with me using the OcUK clan tag from now on.
FYI for everyone:
I've put R9 back on the OcUK Server, along with some supposed "fixes" (admins: check out phogue's website if you're interested, though it's not that interesting). Let me know how it goes...
As some of you maybe aware, DICE have caused a little issue with the latest server release. R9 has disabled the vars commands in the startup.txt file.
Well here is a workaround for anyone who wants it. This will allow you to run hardcore or with mini maps off etc.
1 – Go to your control panel and follow this path: User Home > Game Servers > BC2 Server X Slots >
2 – Then find and click on “Default Config Files”
3 – Find “pbsv.cfg” and click the “edit” button to the right.
4 – if it is empty, just add this line “pb_sv_load pbsvuser.cfg” (without the quote marks) and then click “save” If there is text there because of PBBans then go to the end and make the last line “pb_sv_load pbsvuser.cfg” (without the quote marks) and then click “save”
5 – Go back to “Default Config Files” click on it………… and find “pbsvuser.cfg”, click “edit” button to the right.
6 – Now copy and paste the text below (change the true or false settings as needed to your liking):
;startup.txt information workaround
pb_sv_task 10 -1 vars.punkBuster true
pb_sv_task 12 -1 vars.hardCore true
pb_sv_task 14 -1 vars.friendlyFire true
pb_sv_task 16 -1 vars.killCam false
pb_sv_task 18 -1 vars.miniMap false
pb_sv_task 20 -1 vars.thirdPersonVehicleCameras false
pb_sv_task 22 -1 vars.crossHair false
pb_sv_task 23 -1 vars.3dSpotting false
pb_sv_task 24 -1 vars.miniMapSpotting false
pb_sv_task 28 -1 admin.restartMap
7 – click “save” and restart your server. The settings you saved above will set-up on your server after about 30 seconds after the server has restarted. This is shown in the numbering sequence after pb_sv_task. For example the number you see last ‘28′ means the server will wait 28 seconds after restart before applying ‘restartMap’
NOTE: IF YOU HAVE PBBans “Write confiig” after you did this work around, you will have to do it all over again because your pbsv.cfg is written over.
Agreed. Motion sensors rock
I end up just using shotgun when I'm recon usually. I can't stand most of the rifles.
/re the tags - anyone can use them tbh. OcUK isn't a clan![]()
You mean that FT ? or something else ? What were your reasons for returning to R9, stability ?
I don't have any decent shotty unlocks yet I think i have the first 2 which are Ok but i find that they are either to slow or a bit light on damage, a few more ranks and it should be good.
Well i thought i'd check first, don't want to be presumptuous.
