BOKEH comp
20 Oct 2002
Oxfordshire / Bucks
is this any good for this?
i have no idea if it is or not lol
its with my 70-300mm VR lens, so lowest F/stop i can go is 4.5
It's not likely to score very highly but you should be able to get some great bokeh outdoors; have your subject near the closest focusing distance, then make sure the background is far off.
It has "bokeh" but I think the problem with the comp this month is making the bokeh interesting\a big part of the picture. I'm not sure just having nice creamy bokeh of a non-descript background cuts the mustard, well I hope not as none of my lenses do that! :D
It is an interesting place to start but I think you are only half-way through producing the picture.
Try telling a story.
What is the reason for the makeup, perfume, etc?
Maybe you need a theatre ticket, a picture of a boyfriend, or something similar in the bokeh to give it context and meaning.
it is also not very well laid out. Neither composed like a still life nor cluttered enough to convey a story of mess and chaos.
I think you need two main items. One in sharp focus, one soft, where together they tell us something.
Does this sound harsh? It isn't meant to. I think you are within grasp of a good photo.
Andrew
Andrew
ohh Thanks Gaffer, thats really helpful :) i like that idea
i dont have much time today
but a quick walk out
i'll upload the one for now...
ok last one before i go out...
i think you may be missing the point, and i cant talk because i havent entered yet, but just having Bokeh isnt going to be too succesful.. You need an "angle" or interesting take on the bokeh, imho.
fair enough
i'm still a long way off then, i need to keep practicing!!! :)
dont take my comment in a negative way :) I meant instead of trying to get bokeh in, try and make it the subject.
im not mate, all comments are helpful and appriciative :)
now thats a good tip, i see what it means now, that you've said that, cheers :)
