- 7 Jul 2009
- Newcastle/Aberdeen
"There could be a build up" but you aren't presenting a reason why that would be the case. If I mix blue ink with red ink in some water, perhaps the red will stay on one side, perhaps they'll mix, who's to say? If I was randomly creating ink molecules in situ, being randomly distributed in the jar, what reason would they have to collect into pools of their respective colour? Chance?
About the reactions; I'm not assuming. I read that LH and RH aminos can bond together. I didn't just make that up![]()
Often with ink the substances stay separate, and don't react with one another. They just move around and appear to be doing so, but you can separate them out with chromatography. So it's not the best analogy. You're assuming that these reactions are taking place in a controlled environment, and they actively go out seeking a LH or RH 'partner'. But on a small scale such as this water becomes thick, and to move often they would have to be alive, whereas they are just necessary for life. Unless an external factor was forcing them to mix then why wouldn't there be more of one in a certain are than another?
When I say beliefs, that includes unbeliefs as well.
