Apparently etailers should be getting it this week or early next week.
With the flight ban let's hope they make it to the UK without any delays.
Helios....is it worth moving from a Classified 759 to this. I'm only ever going to run 2 cards, so having 3x16x lanes on the classified is no benefit. And the Rampage should run cooler over no nforce200 chipset. The only advantage the Classified has for me is the fact the pci-e 1x slot for the soundcard is at the top of the board whereas on the Rampage it's between the gpu slots. While this makes no difference using stock dual slot gpu's as the spacing is still very good, I am hoping to get 2 Asus Ares at some stage which takes 3 slots a piece.
this thing already has enough hype, it doesnt need any more.
Release now it, or Vortx will suffer![]()
Now there are rumours that ASUS plan to release it NEXT week, and now ASUS have also said it should be global by 30th of April, starting to take the **** now considering ASUS initially said end of March as Cebit.Stop threatening meNow there are rumours that ASUS plan to release it NEXT week, and now ASUS have also said it should be global by 30th of April, starting to take the **** now considering ASUS initially said end of March as Cebit.
EDIT: I will add some hope though, a member of ROG has come out on the Xtreme Systems forum to say that the boared will be available in germany by the end of this week.
What does this mean for US release Implications?
It's clear that no one knows when it is coming. It will be May at this rate.![]()
From what I've heard there was a couple of delays in manufacture, but that's been resolved and stock should be shipping shortly.
Flanno, Ares is a little way off yet from what I hear. However 5870 Matrix should be available around the start of May - Stay tuned for some reviews.![]()
when exactly is "shortly"
