Poll: ****Official Battlefield Bad Company 2 Thread*****
Which type of game play would you prefer
  • Normal Rush Mode
    Votes: 481 33.4%
  • Hardcore Rush Mode
    Votes: 222 15.4%
  • Normal Conquest
    Votes: 507 35.2%
  • Hardcore Conquest
    Votes: 229 15.9%
  • Total voters
    1,439
WOW.. actually an impressive changelog!
Some excellent changes in there, specifically the Russian brightness fix, the weapon loadout remembering, and the vehicle FOV fix :)
No more MCOM-knifing for you, keyboardcowboy!
Can't see it in there, but did they alter the m-com stations so you have to place a charge instead of using a tank etc?
i found the ping fix didnt help that much.. did make me better for a while then it seemed to make me worse. i was refreshing the server list and the ocuk server jumps from 43 to 93 for me all the time which may be the problem.. so i turned it off :D
which is a shame because when it was working it was awesome (still cant for the life of me work out why they cant get something so basic to work properly)
also why the fudge havent they fixed the black machine gun turrets for dx9?
i still cant get the updated ati drivers to work some im still stuck with it :(
I've only had the hitbox problem with the sniper rifle, everything else is spot on.
Can't wait myself, will look forwards to seeing how the weapons tweaks work out. Hopefully will end the waves of m60 medics and gustavers
OMG!! Finally!
# MP – Kit/gadget loadout saved between sessions
Thank CHRIST for that. Sick to death of it... :D
Nice fix :cool:
No more heli test flights then.
You'll still be able to do that. It'll be like the old battlefield games where points on ranked servers don't actually count until there's 8+ players or whatever and then the map will 'restart' and all points from then on will count. Prevents stat padding.
Shame they haven't opted to alter the models to make them less similar to each other. It's sometimes tough to spot a Russian if you're American and vice versa unless someone has spotted them.
I can normally tell by the bright blue triangle above team mates' heads... Not noticed that before? ;) :p
Although being serious, I can't really make them out quickly enough... although they look different, it's hardly like CS or TF2 where within 0.0001 seconds, you know which team they are... and I've been killed multiple times thinking an enemy is a team mate because the blue triangle of a team mate standing behind an enemy appears to be above the enemy :mad: Happened to anyone else?
I don't often have the chance to look for the triangle at times, you usually become trigger happy when you join a server and shoot anything that moves.
Hmmm well you can see the blue triangle before you can see the player so you should already know there's a team mate there before you see the person... and trigger happy is bad... You should think before shooting in case you might be able to knife them :p
I've knifed quite a lot of people, i'm generally talking about up close and personal situations as oppose to long range.
