Hardware Failure - Possibly Overheating?
1 Oct 2008
Designing Buildings
Hello,
I've just been on Cod4 and things were going fine when all of a sudden the game stopped, and my screen was merging between red and the game screenshot. I could still hear people on Teamspeak for a few more seconds before things went quiet. couldn't do a thing except for reset the pc to which i was confronted with this
dl.aspx
Now this was after a second reboot once I'd seen the odd screen before. I took off the cover and gave everything a blow with my rocketblower (was due a clean anyway) reset again and things seem to be ok.
Temps at the moment across 4 cores are around 30 - 35degrees, with 48 for the GPU. Not sure what these were like during gameplay but is it just a case of needing to get things cleaned out or is it possible that the GPU is on its way out?
Will put Cod4 back on and see if the problem persists.
3D Mark for the GPU may help - it will stress it and then if it fails again it's on it's way out or severly overheating. Opening the case and putting a fan against it may help for checking on a temporary basis to see if it is overheating.
M.
update, since posting this I had windows open for about ten mins and this happened
dl.aspx
Got speedfan open and doing a running check on any abnormal temps while in windows.
Looks like there may be a problem with the gpu, same type of thing happened with a gtx 280 and a gtx 275 i had.
Looks like your graphics card is on its way out - if you have any spare ports though you could swop it over to a different pci-e port to see if it's a dodgy port.
M./
update again. Appears to be the graphics driver. Got a blue screen saying the error lies with the nv4_disp.dll. So going into safe mode with networking to download new drivers.
Looks like hardware problem to me mate, possibly vram. How are the GPU temps? Driver problem would not give you a BIOS screen thats garbled.
I did get the nv4_disp.dll error on the blue screen. it seems to be ok on boot just now but when i tried COD4 again it immediately crashed out again with the red merging with the display image like the second picture i posted. I've updated the drivers to the 197.45 set.
I did have a couple of direct x errors when i was playing a couple of the mod maps on COD4 but didn't think anything of it. Will see what happens now and see if theres anything i might have to change within COD itself :(
EDIT:
Failing that i will try another pci slot for the card to see if thats possibly at fault. if not then i might just buy a new graphics card.
The Gpu Temps aren't too bad sitting around the 50 mark. A couple of times that I have popped out of Cod to check other stuff I've noticed the gpu temp around 65degrees but nothing too horrific.
With the updated drivers its still crashing out instantly on cod but windows is fine. Will try some other stuff tomorrow after work.
its a nividia 9800gt card. Forgot a took my sig off today. Will post full spec tomorrow but i'm sure it can be found on search results in one of my first topics on here.
Yep, the RAM is pretty much screwed on your graphics card... seems a common issue with those 8800/9800 Nvidia series cards, probably overheated at some point.
dl.aspx
This is a classic example of failing Video RAM i'm afraid.
Would you mind if I use that screen shoot on my website?
yeah you can use that for your site.
I'll have to check the warranty for the card to see if i can get it RMA'd through OCuk cos its only a year and a half old so may be able to get it replaced?
yea call them and let us know how you get on :)
tried them tonight after work but couldn't get through / all lines busy so going to give it a try tomorrow at lunch. The funny thing is I couldn't find any sort of information on warranty within the graphics card literature :confused: which i thought was a bit strange.
you want to know something its actually an asus 512mb 9800gt not nividia after all. :eek:
