Avg 25fps
tesselation set to max (some how on a 4850 lol)
1600*1050
Tessellation won't actually be working - press F2 when its running and it will tell you.
Avg 25fps
1600*1050
Yep, definately DOF off, Tesselation high
another run (with wireframe)
The benchmark is bugged imo. The shot clearly shows 27 FPS but the runs are massively more. Not really possible.
Enabling wireframe mode will typically cause fps to plummet - possibly by as much as 75% depending on the drawing methods used.
At chrisavz DOF is Depth of Field and is very intensive in dx11 kills fps at the moment. i suspect your 3 runs of 39fps are without DOF as i get 49fps Without. but then i get 35fps through 3 runs with it enabled. do the test again but press f3 before you start to enable dof then tell me what you get
Read the rest of the posts, I did
