- 19 Jul 2008
- London, UK
No squealing anymoreI don't know if it has already been asked but i'll ask anyway.
Do the capacitors on these cards still squeal under load?
I'm sorry to say it m8, but get used to it
OcUK can only do the best they can if the stock is so constrained...
Totally understand what you are saying but my point is why do they give these dates? very annoying and just disappointing everyone who done the pre-order
I mean ETA dates have been given but from what we have seen it shows overclockers clearly had no idea when these cards were actually arriving and just putting false dates
Also the £458 is taken from day 1... I guess it maybe time to start thinking about given up on the pre-order and getting my money back.
Has anyone else done the same?????
Cheers
mrix
I've just spent the last half hour reapplying the TIMM. When I removed the heat sink there was the thinnest layer of MX-3 seemingly doing it's job of filling any voids. Anyway after cleaning I reapplied MX-3 using the single bead method and seated the heat sink. I then removed the heat sink again! Again the MX-3 seemed to be doing it's job but because the heat sink has grooves I decided to start again with AS5 which is a bit more viscous and spreadable.
I've run another test using kombustor and no discernable difference in temps. To be fair AS5 unlike MX-3 does have a curing time so time will tell!
overclockers clearly had no idea when these cards were actually arriving and just putting false dates![]()
Nice - should be a considerable upgrade!I just received my Gainward 470 - just finishing up benchmarking my old 9600GT, and then I'll install it.![]()
Well now im conused. Should I use MX-3 or AS5? I have both![]()
LOL. I too am confused. The only thing I can say is that MX-3 doesn't have a cure time, AS5 does and there didn't seem to be any difference between the two yesterday. I can only assume, therefore, that AS5 MAY see some improvement in the next day or so....
The thing the worried me a little with MX-3 is that it was soooo thinly spread. Except where there were obvious voids and ridges you could hardly see anything. I suppose this is a good thing but I just wasn't totally convinced.
Do you think my corsair HX 750W ATX Modular SLI Compliant Power Supply will power 2 x 480 sli + a core i7 4ghz or would i be pushing it a bit.
