 - 21 Apr 2010
	£55 Upgrade to i7.
Not sure if the motherboard is capable of x8x8 Xfire.
Also not sure about case would it fit everything or more fans?
	No, not this time:those components are cheaper when bought separately.
The i7 920 4.0GHz overclocked bundle is on offer. With £45 off and price now at £506, it is cheaper than buying the parts separately and the 4.0GHz pre-overclock comes free! (i7 920 £180+Gigabyte GA-X58A-UD3R £157+Patriot Viper 6GB (3x2GB) DDR3 PC3-12800C9 (1600MHz) Tri-Channel £140+Titan Cooler £30+Arctic Silver 5 thermal compound £7=total £514!)
£55 Upgrade to i7.
£55 Upgrade to i7.
	You forgotten the PSU.![]()
£60 Extra for i7 OCed.
Would this complement each other?
I know, but the PSU is placed at top not bottom...I thought PSU is better placed at bottom instead of traditional way of at top, since most newer cases are like that nowadays...the zalman has three fans included!
The £799 AMD build how long would that last before being too far behind?
I know nobody can tell the future but ideally?
