Going to try Windows 7 on my Intel X25-M G2 (INTEL SSDSA2M080G2GC) and just wanted to make sure I get everything right.
1. I have an Abit IP35 motherboard with BIOS from Phoenix Tech. v. 6.00PG, date: 01/11/2008. It has both the IDE, RAID and AHCI as options for the SATA and I have never had any problems with it. Do I need to update it?
2. I bought my SSD last summer. I guess I need to update the firmware? Is this the correct one and the update I need is the 34nm one right?
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363
So I then end up with maybe updating my mobo, then definitely updating my SSD firmware. Whats next? This is my plan but it would be great if somebody could just approve it:
-Change the SATA setting in BIOS to AHCI (will my old storage SATA HDD still work?)
-Boot to the Windows 7 install disk
-Delete the old partition on my SSD
-Make a new partition and quick format it
-Install Windows 7 on the new partition
When W7 is installed I:
-Turn off defragmentation (anything else that should be turned off/on or double checked that it has the correct settings?)
And now I am a little bit lost. I should install Intels own driver for the SSD right? Exactly which one is it I need? Is there anything else that should be done?
