- 26 Aug 2004
- South Wales
Wow, that looks really good. If that were available for a reasonable price it might actually push me over the watercooling for my new build. Have always been put off by the general inconvenience before, but that looks a great solution.
Remember the pump is a Laing DDC and I think it's the 18W version - MSP355 - if you get it included or you can buy the radiator without the pump but made to fit the pump. The radiator is essentially a standard MCR240/320QR which are very capable radiators. The main question is whether the pump/radiator junction is as effective as other after-market tops at increasing flow rates. If it permits good flow, then this will be a very effective combination.
Rad itself is only 34mm, so still won't compete with the likes of Thermochill's and the like, but is'nt a bad rad, just will need higher rpm fans.
Less than 1c delta difference from mcr - thermochill, looking at graphs posted elsewhere. I cant see how that would really matter, so if thats the case lower rpm fans like 1200 or so should work almost as good as on a thermochill rad. The difference is basically almost negilible
Im not talking 1200rpm... more like 500rpm, the thicker rads are designed to work with really low spinning fans, the thiner ones need the fans running faster to have the same performance.
