Each gun has its own bullet drop, stick with the m24 and get used to it as its one of the best. If you keep the mouse held down after firing you stay scoped up so you can see where your rounds are falling. Long to mid range shots are easy, just aim at the "spot" orange triangle over their head. Longer ranges need more to compensate.
I installed the 10.4b cat previews for my 4xxx series Ati card and can now run DX10 again and it still loads quickly
Aiming at that spot triangle is perfect!
Thanks dude just dropped a load of people using that
GOL is acceptable too. I just spent the least time on it. Now i have the M95, I want to learn that well. Soon as I've unlocked the other classesWell..... GOL tbh
Quick question, I just 'unlocked' Tracer and Defib... but I already had those... wtf?
wonderful, EA just fell over :/
also if youre using magnum ammo theres less drop and yeah also watching how the bullet falls is essentual
i get so bored of noobs droning on about how the sniper lags abd you just know the havent worked out taht this isnt modern warfare and theres bullet drop and travel time... although it does annoy me that it only seems to affect the sniper rifles (if anything they should have the least drop)
Yep, all weapons have bullet drop.I think the other guns have bullet drop too.
anyone else having issues logging in? it seems to have forgotten all my stats.#
edit, NM, i see other people are having the same issue
Got into a game but got disconnected.
