Can't get V50 on this code![]()
anyone flashed cooked firmware on Windows 7 ? Following a guide on DM and getting lots of problems.
I used win7 64 bit ultimate with no problems. Using jaf, etc.
One thing i did have to do was set the compatability of jaf and the emulator to win xp sp2 mode.
My list of phones has less models listed than the guide, and when I select the nokia 5800 it doesn't detect the firmware which is in the right directory![]()
I got myself one of these recently, my first smartphone and I'm quite impressed.
I'm a bit lost with GPS, so a few questions for anyone in the know; If I'm using Google Maps, the little blue icon which represents my location moves wherever I do, and updates every second or so. How is it doing this? Is it using GPS? If so, does GPS use my internet connection? What is A-GPS? I've read that this uses the internet connection, but how do I know when it is using A-GPS or normal GPS? Can I specify it not to use my internet connection? Will this affect the speed at which the blue icon updates? Is the GPS service free? Can I go abroad and use GPS with my phone without having to connect to the internet and face the hideous charges associated?
Cheers.![]()
Assistance falls into two categories:
Using information known to the assistance server but not the GPS receiver
-It can supply orbital data or almanac for the GPS satellites to the GPS receiver, enabling the GPS receiver to lock to the satellites more rapidly in some cases.
-The network can provide precise time.
-The device captures a snapshot of the GPS signal, with approximate time, for the server to later process into a position.[2]
-Accurate, surveyed coordinates for the cell site towers allow better knowledge of local ionospheric conditions and other conditions affecting the GPS signal than the GPS receiver alone, enabling more precise calculation of position. (See also Wide Area Augmentation System and CellHunter.)
Calculation of position by the server using information from the GPS receiver
-The assistance server has a good satellite signal, and plentiful computation power, so it can compare fragmentary signals relayed to it by GPS receivers, with the satellite signal it receives directly, and then inform the GPS receiver or emergency services of the GPS receiver's position.
If A-GPS is enabled, will it automatically attempt to use a data connection? So far through using Google maps and Nokia's maps application, I haven't once been prompted for a connection. Does this mean that A-GPS isn't being used, or that it's automatically using my T-Mobile connection?
I'd rather it prompt me about using a connection, especially when I'm abroad.
My mum is going to get this phone today. She had never used a touch screen phone before and is a bit of techo phobe (got the phone for free). Anyway, am I right in thinking the branded versions come with a much older firmware? I have briefly used a 5800 before and seemed alright. Basically I want to make this phone up to date (if it requires flashing, is it safe and easy? Can it be reversed?) and as easy to use as possible. What apps do people recommend for a middle aged woman with no previous modern/touch screen phone experience? Thanks![]()
