to late sold all my q9650 and parts , got bored by intel bring on hex
@stock 3.2 my idle is ... wait for it .. reported by AMD Overdrive .... using an H50 ... single fan blowing in .... 19.5C ... ambient room temperature measured by a room thermometer ... 26.5C
well AMD Overdrive may not be the best tool for the job
After 5 mins or so 100% load x264 encoding the temps have settles @ 35.5C all @ stock clocks
from what I can tell from my experience of the software Im using the X6 is beating the i7 920 but only just (my 920 is at 3.2Ghz) ... probably only 2 or 3 fps in it but of course the X^ would fly ahead at this task if it had the same overclock
more testing and then see what AMD Overdrive can clock it too
Cozzy
get in the bios u lazy man and do it the good old fashioned way core temps = fake...
using HWMonitor, TMPIN0 or TMPIN1
for crunching seti would an Intel 920 or a x6 amd be better?
one is motherboard and the other is the real cpu temp...TMPIN0 = 39
TMPIN1 = 42
does that sound more realistic ?
u have the same motherboard as me? if so, its TMPIN0 = motherboard, TMPIN1 = cpu
now i've upped the voltage to 1.425v because prime crashed after 2hours.
i hope it's not a temp issue.... TMPIN1 cpu temp max out at 48c, core temp max out at 41c, TMPIN2 (no idea what it is) max out at 56c
thats if those temps are true
your on the same board as me and my temps have been higher with higher vcore so I doubt its the temps ...
my chip wasnt stable @ less than 1.47 as read by HWMonitor which is a setting of 1.45vcore in the BIOS .. passed OCCT and IBT now on prime so will let you know in 90 mins or so if gets pasted 2hours barrier
