[TW]Fox;16464484 said:Surely bumper replacement and spraying is another 500?
So if i can get the repair done for £200
Who'd honestly swap a Mondeo for a Matiz?
Have you actually got quotes done on this or are you just pulling figures out of thin air?
Do you just troll in every post you make? Honestly who would just post in a thread to be an ass
Neodite said:Honestly who would just post in a thread to be an ass
Indeed, most likely someone who knows more than the OP.
Did you get the car inspected mechanically by a specialist ?
Not when i got it no, all i did was a test drive, and HPI checks etc.
Ive taken it to my local garage since and he said the engine is sound, he also checked under the car where the damage is to make sure there was no hidden damage
[TW]Fox;16464437 said:The max it will cost? That is the hardest most expensive panel to replace. I did similar damage to mine a few years back and the bill was thousands!
Because you need to work it hard to keep up with normal traffic![]()
Not sure if your joking here but you are right, I used to drive a Hyundai Getz 1.1 and on motorways it would always drop below 25mpg...
 IME if you drive everywhere thrashing the nuts off a small engine, you will get less MPG than driving around in a car with a more powerful, less stressed and bigger capacity engine.
Does anyone have any links for howto replace the bumper + light? pics would be a bonus, gonna be doing it at work so dont wanna be spending the day faffing around![]()
Obviously depends on the scale. A cupboard fell on my rear quarter and the bill was *only* 300 quid odd
