If what's been uploaded to RS? The torrents have been posted in this thread already. That's the main file. Then there have been two patches since:
http://drop.io/retrofuture/asset/mechwarrior4mercenaries-51-03-01-0017-to-51-03-01-0018-mtx
Patch 18.
http://drop.io/retrofuture/asset/mechwarrior4mercenaries-51-03-01-0018-to-51-03-01-0020-mtx
Patch 20 not sure what either of these actually do. I thought 18 was to remove the key check and to unlock clan mechs and stuff in the campaign as drops.
Interestingly, the MTX files they use... they are just renamed .zip files. Open them up with your extractor of choice. With the 17 file, which contails the entire game, just extract it somewhere, run MW4mercs.exe and it plays fine. Unfortunately, its not that simple for the two patches, you can unzip them, but they contain a couple of files which apparently need to be unpacked with a different program, which is a whole lot more complicated.
Thanks to SA for most of the info in this post
Patch 18.
