i recently flashed the bios on my xfx 5970 BE to enable fan control and also installed the overvolt tool and increased the voltage on both settings to max and increased the gpu setting in CCC to 875/1200.
i ran 3D Mark 05 and only got around 15K, this is with my i7 930 at 4ghz and an ex 58 ud5 mobo, 6gb ddr 3 mem. i'm pretty sure that when i first ran the card on 3D mark 05 a couple of weeks ago i got about 30k. i've put the gpu back at stock levels and the score is still the same?
vantage was about the same score as well. all my games run perfectly fine and smoothly at max levels. i was just confused about why my 3D mark scores had changed drastically?
i was hitting about 60fps on both 3D mark benches, as well as 60fps on Batman AA bench and about 60fps on JC 2.
when o'c the 5970 would it be safe for me to set both voltages on max using the overvolt tool and stock fan with 875/1200 in CCC. finally, i guess i should o'c both gpu's in CCC at 875/1200.
