Fox speaks the truth.
The clip of the American pilot who landed in the Hudson was incredible. Not even a hint of panic, just "I'm going to land her in the Hudson" or something.
The clip of the American pilot who landed in the Hudson was incredible. Not even a hint of panic, just "I'm going to land her in the Hudson" or something.![]()
I am not an engineer so can someone explain why the engine was flaming at regular intervals ? Air / fuel mix interrupted ?
I would have thought it was chunks of bird that caused the irregular blasts of fire. Probably got stuck inside and bits of it kept getting pushed out rather than all at once. Looking again you are right, it does seem to blast, then stop, blast, then stop at a pretty consistent rate, which would suggest something more complex.
Again im not anything that comes close to an engineer on aircraft, so im probably wrong![]()
Yea it wasn't the bird causing the fire. Well I suppose it was the INITIAL cause. When the engine does that its called Surging. It basically means that the airflow through the engine has become disrupted. In this case the bird most likely bent a number of the blades and stators which caused the airflow to get upset. The upset air will cause a number of the blades to stall and re-pressure repeatedly. In minor cases just reducing the thrust on the engine can restore the airflow, however in this case the engine is actually damaged and so needs to be shut down.
Pfft ditching is easy, we even have a checklist for it lol. Seriously though, the Hudson crash was some pretty impressive stuff. It was the first totally successful commercial ditching. Hats off to the crew. I actually fly the same type of plane they were in, A320-200.
Which skies do you feel safet flying in?
BORING!
Planes landing in cross winds for the win!
BORING!
i'm less worried about flying in one that one dropping on my head. You should see how many are flying over our heads at any one time.
Think you are safe on the ground .... lol
BORING!
