I'd go with that, you can also use tables to calculate trajectory too but they are probably just used as a backup now.i think the spotter has a pda style computer that does a lot of calculations.
It's a shame that we haven't ThomThumbs2010's input considering his extensive expertise and experience in this area....![]()
That made your weekend didn't it. Must admit gave me a few chuckles.
 I'm waiting for him to return under another Username...
You and Tefal are correct, PDA based Rangefinding GPS and ballistic software is common place. They can give you Range to Target, Elevation Adjustment, Windage Adjustment. Temperature reading, Barometric pressure, look angle and rotation and movement translation sensors. They are compatible with DOPE tables and MilDot scopes.
The Intervention for example comes with a tactical ballistic computer.
Knight Armaments do an external ballistics calculator for the ipod touch with mounts for various rifles.
Laser Range Finders are common place also.
Just curious do seals or grey fox use the intervention i know sniper scout are mad on their barret and remingtons.
I didn't realise the L96 was such a good rifle, id have fired that if i had known at the time, im the SA80 was a pos.![]()
'It's not about how many people you kill, it's about the team.
