New DGteam Firmware (DG834GT)
So quite often in the evenings I notice my SNR goes down to about 4-5dB. Is this something the router should sort or is it related to my line/ISP?
Certain routers hold your SNR closer to the target better than others - the DG834GT is one of the best (a long side the Speedtouch ST585v6 & 2Wire 2700HG in my opinion) but at night it will be more unstable as the street lights come on, people turn on their lights, central heating comes on, tv's are turned on and so on - they all cause electrical interference which make your line noisier, making it harder for your router to keep a stable SNR. Around Christmas time my SNR will fluctuate quite a bit as Christmas lights are the main offender of electrical noise :p
There is not much you can do about it really, you already have a Broadcom-based router which are able to keep a stable SNR better than other brands of chipset :)
Has anyone else been getting really slow WiFi access and Web GUI access with the latest DGTeam firmware by the way? I've had to switch back to the standard DG834GT Netgear firmware as it's unbearable over wireless! (same wireless channel, the least contended one around here too)
Cheers :)
Cheers :)
Thanks, very informative :)
Can I do anything with SNR percentage to improve this?
Cheers :)
Accessing the web Gui over wifi seems perfectly fine on mine running the latest, speeds as they should be
All you an do is move it up or down, everything generating noise along the lines length contributes i.e. the whole street. It's worth pointing out that how low you let your snr go depends on your preferences but there's a point where the errors created outweigh the increase of speed that people don't usually pass.
Personally my line's quite poor, I have a snr drop of 5-60% daily (morning and night) but the router keeps a stable line right down to 0.8db :D
Down to 4-5db from what?
The firmware works great.
Some welcome new features to my DG834GT
Got a stable 1mb speed increase on my ADSL2 line by dropping the SNR down to 75%.
Good job DGTeam :)
1018 is out, half bug fixes half adsl driver experiments it seems.
ADSL DRIVER UPDATED TO VERSION 026 for Annex A Brcm models;
ADSL DRIVER UPDATED TO VERSION 025d for Annex B Brcm models (with phyRe technology support);
IPROUTE2 TC UPDATED TO VERSION 2.6.33 (with some code optimizations);
Added TLS client authentication support to GT/PN/G/N vpn section (possibility of connecting auth-based vpn servers directly);
Added diagnostic & custom setup section links to modem menu webframe;
Added N2000/N2000B web-size optimized custom setting top gif reducing total space amount (Kussolino);
Fixed bug on udhcpd (quick startup could cause wrong static lease assignements);
Fixed orig bug on N2000/N2000B led functionalities (wrong vanilla kernel led module);
Removed snmpd section on N2000/N2000B due to flash space overhead;
Removed dnrd & reaim proxies on N2000/N2000B due to flash space overhead;
Removed WPS, smart wizard & upgrade, adsl test, TR069 & parental control sections on N2000/N2000B due to flash space overhead;
Removed orig section help webpages on N2000/N2000B due to flash space overhead;
Orig target-filesystem cleanup removing unused webpages & gifs;
Code cleanup & revision on some busybox internal filters & editors;
Code-cleanup on dgteam software improving speed & reducing code size & memory usage.
Just remember 23o are the drivers from the last release, and seem to be the only ones that won't result in a brick :rolleyes:
im using 026 driver in 1018 driver.
the advance adsl settings dont work they are fault. i have to keep it on default.
im using dmt tool to adjust my snr, atm as the web config seems broken.
overall it seems ok. ive posted my stats on another thread.
Well i decided to upgrade my firmware to 026...Got a shiney white brick now :(
The guys at dgteam have really dropped the ball on this one,not impressed at all
Although i do realise that it is at your own risk
Tried the recovery utility no routers are found:(
Dont think ill be upgrading from 1014 for a bit thanks
Wish i had waited too now :(
Am looking at routers to replace the dg834gt(must be able to adjust the snr as i have a poor and long line)
currently looking at a
Billion 7402NX BiPAC VPN ADSL 2+ Gigabit Wireless-N Router W/ 3G/HSDPA Support (300Mbps)
Any idea's when they will have a new firmware for the DG834Gv4?
Got the old one on at the moment, it's rock solid but always happy for the latest and greatest :)
Have you tried using the recovery utility after turning the router off, and back on while holding the reset button in. Your lights shud start flashing alternately, this means the recovery utility can now detect the router.
Yup tried that mate,got the flashing lights but no router is detected so far have tried about a dozen times,even tried the puppy linux route but failed to get the linux to work with the pc
Just upgraded mine to the 26 it seems to be working fine still im connected using it now, how come yours has bricked?
Beats me mate it all appeared to go fine then when it finished no internet light,power light is on so are the lan lights but cannot access the router at all.deader :(
Got one off the bay for £21 last night(decided it was the cheaper option rather than get a more expensive choice)
Currently using a 2 wire BT2700HGV which is working fine but not as fast as i can squeeze out of my line with a dg834gt,seems more stable though
What is the most stable firmware for the DG834 v4 then?
Also on a BT 2700HG-V, but want to try a v4 that I have laying around.
1012 was fine for me then 1014 was not as good,was having ip reservation niggles,name unknown,still usable but then alon came 1018 and it all went pear shaped for me anyway
