Is my burn test working?
10 Mar 2010
London, UK
I just D/L'd Intel Burn Test so I can start OCing and wanted some basic stats first off.
However when I run it claims to be complete in miliseconds and I don't see any results!
Am I doing something wrong? (Specs in my sig)
Cheers!
Howie.
Change the times to run to a higher value? Never got round to using IBT but I think its a good guess. :)
Gave it a go - ran 5 times (the min) and 20 times (the max) at max settings... I'm supposed to get a list of times etc according to the readme grrr. Also nothing happens... my CPu usage doesn't move from 0-1% and the CPu-Z shows it's still on quiet Speedstep half power modimajig...
Forgot to mention am running W7 64bit (I'm sure I've seen it used on YouTube on this OS).
Tis quite strange. If no solution to this I guess I'll have to check out some other software. I was trying to avoid Prime95.
(On a side note, is Idle supposed to use up 2GB of memory? :O )
With ibt v2.4, i had to manually set thread count to 16 to get it to run, though LinX as suggested is a good alternative.
Well:
Tried setting the thread count manually - no change.
So, I got LinX and ran that... Only for nothing to happen!
I really don't get it. It's running but it's not working :( (screeny below)
Oh, and it won't 'stop' when I hit the button. I have to actually close the program altogether (if that means anything).
Thanks for your help so far :) any more suggestions?
Well, I heard somewhere tat it might have been causing a problem that I was trying to use too much Memory in LinX. I tried turning that down and even lessened the problem size and left it longer, but still nothing.
*sigh*
Howitzer - Are you running it in administrator mode?
Yup. I tend to run everything like that lol.
The OCCT program worked great! Thanks for that recommendation :)
No idea why the others didn't work though, how odd... Still, at least I have something to go with.
THanks all for your input :D
