Room Layout Ideas
What the hells that mean...speak english pls.
Sounds like you need to clean your room first - then think about moving things around.
haha tell me about it,Yeah ive got too :)
Your mature :eek:
Just seen your dimensioned drawing, you have a 5m x 3m bedroom and you need help organising furniture?!
Lol nah its not that big,That was just a default template size on the software,I just wanted to try diffrent layout ways.
If its to scale.
I hate having a bed in the middle of the room. Ruins the space.
EDIT: seems it's not, although it is interestig everyone chose a similar layout. :p
As for the OP making it hard, i'm a bit like him ad I don't think it's the final product, more the doing that's the fun part (designig your room on paper).
Yeah it was just a quick try,,,nothings to scale,BUT....everything should fit whereever i put it cos its not exactly a small room.
I basicly just wanted some layout ideas,it doesnt matter about dimensions.
Don't bitch about the boiler cupboard, that looks like an epic sized room. I have a bed, a tv and a wardrobe in mine, then enough space for the door to open...
Me I'd push everything into one corner and stick a drum kit in the middle!
But instead I say bed in bottom left corner horizontally. Little table next to it for beer holding purposes. Computer at the end of the bed for porn watching purposes.
Everything else stick in another corner or something :D
Haha!
But anyway if you cant realise which way around things should go in your room by just looking at it you have problems
Its YOUR room, make it how you want :)
I do have problems yes :D,i think the only way that il do it is to have a good cleanout and then try the thingsin diffrent poss,My tanks in need of a clean anyway so i can moved it then when its empty.
Btw.....very very VERY nice Pug 106 you have :cool:
Measure it all, put it in sketchup and use the 3d warehouse to download models people have made (as they've made most of the Ikea catalogue for some reason).
