Adding cruise control to mk3 mondeos doesn't look too bad: http://fordwiki.co.uk/index.php/Cruise_Control_Retro_Fit_-_Petrol_Models
I've never tried though
Would it not be easier and cheaper to reset the tripcounter when you fiull up, write down how many litres you put in, divide by 4.55 and and then divide the miles by the number of gallons you filled up with?
Lots of marques do it, Golf Mk4s cold be retrofit with cruise control for £100 iirc.
^^ You think that's bad try the VW con that my friendly salesman helped me dodge.
Factory fitted cruise (as on option) £250
Dealer fitted cruise (on delivery) £170
Same thing! :\
(I got it thrown in for free)
gave him my number tho incase he gets one in.
Went to my local scrap yard after work last night and he didn't have anythinggave him my number tho incase he gets one in.
Looks like im going to have to browse the bay daily
Think ill give cruise control a miss tho, i don't trust myself that much lol
Apparently the V6/petrol/desiel are all differant![]()
I know on the Focus adding variable intermittent wipe is just a case of swapping the stalk - 1st mod I did on the RS to be honest. I'd guess it's probably much the same on the Mondy.
http://www.fordmondeo.org/forum/showtopic.php?tid/796612/
I tried it on mine - was a PITA getting the key to fit as the flip keys are for the new flat type blade, not the old barrel type. Ended up needing to glue it, which looked like a 5 year old did it.
Programming the remote is simple, but you'll need to destroy one of your existing keys to pullt he PATS chip out.
Not worth it IMO, better off with a Jag flip key if it really bothers you
, so I just pull the PAT chip out of my non-remote spare key stick it in, program it and it will work?http://cgi.ebay.co.uk/Ford-Mondeo-J...arts_Vehicles_CarParts_SM&hash=item2c54017b9c
Old barrel key with new type of fitting, so no super glue required.
I don't want a Jag one cos they look pants, so I just pull the PAT chip out of my non-remote spare key stick it in, program it and it will work?
Ooh, that didnt exist when I tried it!
Yup, sounds about right.
If you only have 2 keys, I'd be inclined to get a third non-remote key programmed just in case. If something goes wrong and you're only left with one, you wont be able to program any more without an expensive trip to the dealer
)Do you know how much it costs to get a non-remote one done for me, surely that would require another pats chip? (Sorry I know nothing about this)
£7.50 and program it yourself using the other 2
http://cgi.ebay.co.uk/FORD-FOCUS-MO...arts_Vehicles_CarParts_SM&hash=item25537d7bba
Better safe than sorry, otherwise it could be £120+ at a dealer
Acctualy keep them comming
: http://fordwiki.co.uk/index.php/Category:Mondeo_Mk3My god, the focus didn't have that? I thought that was like a standard feature, like including wheels. Jeez.
