Big Bike Thread
Status
Not open for further replies.
my lbs is a ripoff, i took my bike in for a service in feb this year and i said to him to change the brake pads wether they needed doing or not to some tektro pads, got a new set of pads today to fit myself unhooked the brakes (v-brakes still) to find to my dismay that the rear had cheap generic ones so i unhooked the front and i think they were used tektro ones from my rear because they were way past the wear line.i've used his shop for years but now i going to try the other one thats local to me.
Anyone using the Ribble bike stand? I think I need one. I live in an apartment so can't give my bike a good wash down, I have to use a toothbrush and damp sponge/cloth to clean it and it takes ages. And sitting on the floor kills my back.
I've seen a park tools one at £100 but it's a little too expensive, but the Ribble one looks ok.
Am just seeing if anyone has used one before.
That seriously is down to personal preference, but id say around 40-45 is a decent figure to start at, then tweak from there.
Im still faffing with my pressures, cant seem to find anything that suits me lol.
Tyre pressure depends on your bike, the size of tyres and your weight. I'm 12stone and can get away with around 26psi on 2.3/2.4" tyres, a little more for 2.1's. Upping it to 30psi for some trails.
Tyre pressure depends on your bike and your weight. I'm 12stone and can get away with around 26psi. Upping it to 30psi for some trails.
Do you not find the tires drag a little with the low pressure?, im only 8st and if i tryed 26 in mine they would drag like hell, at the moment im at around 48 and they are still dragging but tires are only supposed to go to 50 so im out of luck.
They can a little, but the trade off is increased traction. And with tubeless it means no snake/pinch flats....which is nice.
Cool folks, thanks for the info. Having only recently got my Cube I'm kinda used to using my track pump to stick @110-120psi into 700x23 Schwalbe Stelvio road tyres so 30-55psi just sounded a bit alien to me. :p
just picked this up for commuting to work
hey there guys. First post in this thread. I recently (2 weeks ago) got a scott scale 50. I am loving the bike, but am thinking of changing the stem for a couple of reasons. Firstly, i feel that i have to lean over just that little too much, Saddle height adjustment just doesnt help, and the stock stem must be atleast 120mm. the bike is predominantly white and i also thought a white stem could look cool.
So my question is, does anyone have any recommendations for a decent stem thats white. Need a 31.8mm clamp diameter and steer tube is 1-1/8". Also, would like not too spend a massive amount
Couple of other things, how will stem length affect handling, never changed a stock stem before. And also, is there any way of knowing if the new stem will fit properly in terms if its height on the steerer tube.
Apologies for all the questions
Thanks;)
Thanks;)
Generally a shorter stem will quicken and make the front end more livley and seem slightly lighter even though it isnt due to it being closer to the centre. Also if you have spacers on your steerer which most bikes do these days as the steerers, are generally uncut on new bikes any stem will fit, just juggle the spacers to get it right for you.
As for the stem i cant think of any white ones, but for length probably a 90mm would be a good starting point. If you have a LBS, you could go in and ask them and see if they have a few to check out for lengths. Oh an also there is the rise of the Stem itself, again probably best seeing if a LBS has a few to check them out.
edit/ 2 This one in 90mm nice black colour, i know its not white.
Edit/3 Found a nice white one, has the 90mm
Tyre pressures - just pump them up till they're nice and hard, slightly harder on the back than the front - simple! :P
No pressures to worry about! I don't want to carry a pressure gauge in my pack anyway!
cheers mate. appreciate the links and your input. Ive found quite a few stems. Would appreciate it if someone could have a quick look through and maybe give some opinions.
Also, im really not sure of which length stem to go for? Would 50mm be too short?
Here are the links
http://www.chainreactioncycles.com/Models.aspx?ModelID=29332
http://www.chainreactioncycles.com/Models.aspx?ModelID=35442
http://www.chainreactioncycles.com/Models.aspx?ModelID=31143
http://www.chainreactioncycles.com/Models.aspx?ModelID=15837
Cheers guys. ooh, and they are all in white:D
Status
