I have just bought a Western Digital WD20EARS 2TB Internal HDD.
It will be used as a secondary HDD - my primary is a WD6400AAKS.
Do i just plug and play? Im running XP SP3 and i might like to partition the drive in half, not sure yet - which is a decent program to do this?
Also should i run a program to make sure there aren't any defects/ bad sectors on the hdd?
Anything else i should do?
cheers.
cheers.
Sorry if it came across as being a bit picky, BTW - not the intention!
